Released on October 23, 2012. Core i5 or Core i7 Processor. Apple Fusion Drive.
169 Questions View all
Did I break the power supply case ground clip?
You might respond with, "shouldn't I know if I broke it or not?". You might be right, I failed to take a picture upon putting everything back together -- and was unable to find a clear enough picture online of the back/inside part of the case.
Right behind the power supply there's a bit of bracketing that is attached to the case (this would be the front infrared/led).
My remote works, the power led works but there was a broken piece of metal after I put the psu/motherboard back after a dual hdd install.
Note: There doesn't appear to be any issue with my mini, but I'm concerned if this is a significant part of the grounding. The power supply looks like it's completely cased in a plastic mold, so I don't know if it is a ground or just a friction pin.
Add a comment
1 Answer
Chosen Solution
A broken piece of metal = yes you broke it. . . only you can determine if that piece of metal shorted the logic board. A high power magnifier and a good light should show burn marks. AHT might be able to diagnose a problem.
Good Luck,
If this answer was helpful please remember to mark it accepted.''
Score 1
Add a comment
Add your answer
Christopher will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 565
