MBP (A1260) Kills Batteries
My A1260, (S/N 8YK0) worked fine until the first battery finally gave up the ghost after 3 years. I bought a new one from Apple and it charged fine, but after a month of normal use that changed. The pull down menu for the battery said "Replace Now" and the computer would not last 10 seconds without the charger. I suspected there was something wrong with the computer so I bought two, new, OEM batteries from a third party: TechOrbit. I verified that it replaced the A1175 and was a Li-ion, 10.8V, 60Wh battery.
These two batteries had the same problem the first day. I believe there is something in the computer, a logic board or similar, which is responsible for recharging management but is failing somehow.
Am I on the right track? If so, what part is the likely culprit?
Add a comment
1 Answer
Chosen Solution
Try resestting the PRAM and SMC and see if that helps.
Also if before the "old battery" went south if you installed or updated any applications a change in background processes running could cause the sudden battery drain. Check Utilities > Activity Monitor > CPU tab, set the pop-up menu to Active Processes, click on the CPU column header to sort, and see if anything is using a high amount of CPU capacity, .
If this answer was helpful please remember to mark it accepted.''
Score 1
Comments:
Resetting the PRAM and SMC was the only way I could start the computer without the battery. Before that it would simply sit there when I pressed the I/O button. That issue is resolved now.
I did as you said and looked at the Activity Monitor; nothing out of the ordinary - 90% idle. I would not call the problem a sudden battery drain so much as the computer seems to be damaging the battery. Perhaps it is overcharging.
by
Add a comment
Add your answer
ussseaw0lf will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 777
