Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3238 Questions View all
Headphone Jack not working, after Screen Replacement?
Hi,
After replacing a broken LCD screen, my headphone jack has stopped working. Everything else works as before.
Solutions already tried :
1) Cleaning with Q-tip
2) Blowing Compressed Air
Both solutions didn't work.
Also, took apart the phone again & put it back together. That didn't help either!
What might be the issue? Any and all suggestions are welcome.
Add a comment
1 Answer
Chosen Solution
You could have damaged the ribbon cable that connects the headphone jack to the logic board, I would replace it after making sure its plugged in correctly and still not working, the cable has a new jack on it so your covering all bases, iPhone 4 Headphone Jack & Volume Control Cable Replacement, here is the cable, https://www.gounlock.com/details.php?ite..., good luck, If this answer was helpful please remember to mark it accepted
Score 1
Comments:
Hi Mitch,
Thanks a lot for your answer. The ribbon cable was indeed broken, & so close to the jack itself that cursory exam didn't show it.
Had to take it out completely to actually see it.
Ordered a new jack assembly, hopefully fix it over the coming weekend.
Thanks again!
by
Add a comment
Add your answer
kgautam9 will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 23
Past 30 Days: 101
All Time: 5,337
