Are the displays interchangeable?
I have a MBP 1260 with a cracked LCD and a MBP 1211 with several things wrong on the logic board. Wondering if I can swap the display assemblies or even just the panel if that works better. I know that the display from the 1211 is cfl backlight and the 1260 is LED backlight but the replacement guides look to be the same process so wondering if it'll work.
I have nothing to lose trying it since both machines are kind of unusable but if it is know that this won't work then I won't bother.
Thanks for the help.
Nathan
Add a comment
1 Answer
Chosen Solution
No they won't swap...
If this answer was helpful please remember to mark it accepted.''
Score 1
Comments:
It seems it is possible though. See post below
by
Although they are different, this post tells you how to do the swap, albeit the other way round.
Display compatibility from A1226 to A1211?
by
Add a comment
Add your answer
dunnhatani will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 285
