Model A1288 / 8, 16, or 32 GB capacity
451 Questions View all
replaced battery (now good) and glass, but display is very, very faint
Using your tools and components, I replaced the battery of our 2g iPod Touch. I broke the glass during disassembly, and replaced that with a fixit kit as well. After charging the device it powers on, but the brightness level of the display is "just above black." I could navigate to the brightness settings panel, and played with the settings (auto off, max brightness), but they had no effect.
did I make a mistake while re-assembling the components? It was working fine before the battery died (well over a year ago, granted).
Thanks.
Add a comment
1 Answer
Chosen Solution
lkv7, check your board and connectors for corrosion, as well as other damage. The way you describe the error, it does appear as bad backlight. Could be a bad LCD or a logic board issue.
Score 1
Add a comment
Add your answer
lkv7 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 286
