The current line of iPod nanos comprises seven different generations.
1004 Questions View all
Is a 25watt soldering iron powerful enough for battery replacement?
Hi
I am going to replace the battery on my iPod nano 3rd generation and I was wondering which soldering iron I should use: I have 2 fixed temperature soldering irons a 25watt and a 40w As this will be my first ipod repair I want to make sure I have the right soldering iron :)
Thanks in advance
Score -1
Add a comment
1 Answer
Chosen Solution
either one should work if you're careful. I suggest the 25W because if it's too hot you may get a bad solder or accidentally damage other components. Check out the soldering guide ifixit made, it may help www.ifixit.com/Guide/Repairing+Soldered+Connections/750/1
Hope this helps!
Score 1
1 Comment:
Thanks, I couldn't find the answer to that anywhere :)
by
Add a comment
Add your answer
Alex wetton will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 646
