Replace Superdrive with 2 hard drives?
Is it possible to replace the superdrive with two 2.5" hard drives? Just want to use duo SSDs to replace cost.
Ronnie - You only have two SATA ports in this system both are in use (current HD & Optical drive).
So you'll have to decide which device you are going to swap out. You can either take the optical drive out to install a second HD or SSD or take the current HD out and put in a SSD.
There isn't enough room or power or I/O connections to supply a third device.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,571
