My I pod wont charge
hi guys my iPod wont charge it is out of battery and i plugged the USB into my computer and it comes up with the apple sign and then turns itself back off again how can i fix it?
lallana fan, try to charger it on an AC charger and see if that makes a difference. the Ac charger will supply a higher amperage and it is possible that the battery has discharged below its threshold. If that does not help, start by cleaning the dock connector. Use some isopropyl alcohol and a few puffs of compressed air. Check for broken, bend or corroded pins. also, try a different cable. If none of that works, replace the battery. Use this guide to get it done. If nothing else it will give you a known good starting point, should further troubleshooting become necessary. Hope this helps good luck
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 479
