Repair and disassembly guides for Kenmore Microwaves.
130 Questions View all
Why does my microwave not heat up food?
My microwave turns on and runs,display is fine,timer and all works but it just don't heat up anything!
Score 1
Add a comment
Chosen Solution
joshua, for the longest time the consensus on iFixit is to replace the whole unit. Microwave ovens generate high voltages and dangerous amounts of radio-frequency radiation. Attempting to repair one is NOT for the amateur. I advise recycling it and getting a new one. On the flipside of this, you may just give us the serial number and we can try to find a common simple problem, but anything above that, you should leave to a professional.
Score 3
Comments:
302ta00882 kenmore just wondered if it was a fuse
by
Joshua my microwave looking good what do you suggest? when it is just not heating everything else looks good
by
970C85342310 not heating even water
by
Add a comment
I received a microwave to repair and resell a few months ago with the identical problem. Everything worked except that it refused to heat, so the problem was obviously not the ceramic fuse(s) hidden inside microwave ovens. I removed the outer cover, shorted the super capacitor so I wouldn't get zapped, and proceeded to investigate. I did go ahead and check the fuse just for the heck of it, but if it had been blown the microwave would have been totally dead. No lights, no nuthin'. I noticed that there were 3 micro safety switches on the door latch assembly. Upon testing each, I discovered that the top two were working just fine, but the third one at the bottom was not working. I proceeded to replace it with a like switch that I had salvaged from another appliance, tested the oven, and it has since worked perfectly.
Score 2
Comments:
Where is the door latch assembly
by
Directly inside the control panel where the latching hooks on the door enter the panel.
by
Add a comment
I hired a repairman who told me the same thing. Too expensive to repair....just buy a new one....is this the only solution? Isn't there enough waste? The oven was manufactured in 2006!
Jim T.
Comments:
Yes there is and you are right, but if not done right those things can do you harm. Do the risk outweigh the benefits? What microwave do you have and what does it do. Lets keep it academic and see if we could find a hypothetical solution to your microwaves issue.
by
Add a comment
i have kenmore elite microwave
i change already the fuse but cannot heat what is the problem
Comments:
First, put your nose to work. Sniff around the control panel. If it smells like burned electronics, the unit is done. If it doesn't smell, then it could be one of the door safety switches, or the super capacitor could be dead.
by
Add a comment
Add your answer
joshua will be eternally grateful.
Past 24 Hours: 53
Past 7 Days: 301
Past 30 Days: 1,392
All Time: 32,825
