Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
212 Questions View all
will a SATA III- 6 Gb/s HHD work with my old iMac?
I have a WD1002FAEX SATA 3 HHD from a crash PC. Is it compatible with my old iMac EMC 2118? The data transfer rate default is 6 Gb/s. Do I have to reduce it to 3 Gb / s with the jumper settings to work?
Model iMac 2.16 GHz Core 2 Duo
Thanks
Score -1
Add a comment
Chosen Solution
Yes, you will most likely have to set the jumpers down. You will know as soon as you try to format it with Disk Utilities.
Score 2
2 Comments:
Thanks for your help. In the end I installed a WD Caviar Green 2TB (WD 20 EARX). I lowered the rate to 3 Gb / s with a jumper and the computer has recognized the hard drive perfectly. ¡¡Fantastic!!, has gained greatly in speed.
Before I cloned the hard drive in an external box with Carbon Copy Cloner.
Thanks to iFixit tutorial installation was possible without difficulty.
by
Glad I could help solve your problem ;-)
by
Add a comment
For this iMac haing the latest drivers it should regognize up to 3 Gb/s
1 Comment:
by
Add a comment
Add your answer
Enrique Girela will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 681
