Repair information and guides for the fifth generation of iPhone. Model: A1387
2191 Questions View all
No display, Not charging, no itunes
Hi,
i have replaced probably my 10th Iphone 4S a minute ago and it wont turn on.
i have checked everything and all seems fine inside the Phone.
i plugged i in the charging dock and nothing happens or nothing is being displayed.
i plugged it into itunes and nothing happed at all?
any suggestions on what it could be?
THANKS !!
Score -1
Add a comment
Chosen Solution
Disconnect and reconnect Charging Dock Flex Cable very carefully. Disconnect and reconnect Battery Flex Cable very carefully.
Score 1
Add a comment
Does the phone show signs of water damage? Ive seen phones working but after doing a replacement something that was slightly corroded or damaged stopped working.
Try plugging in another screen to test. Pull the battery and just pop the LCD and Digitizer connectors and then plug a text screen into there and see if anything happens.
Also, are you plugging it into a charger thats plugged into AC directly or into a computer. It would be wise to try a charger in the wall outlet and make sure its getting a charge directly.
Add a comment
reseat all cables you messed with most of the time it happens with a cable having a bad connection. dust and debris gets stuck on those little pins to block a connection.
Add a comment
Add your answer
tom will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 450
