Model A1369, 1.6, 1.7, or 1.8 GHz Processor, 64, 128 or 256GB Flash Storage
271 Questions View all
MacBook Air 13" keyboard imput incorrect, not charging?
Hello!
My Macbook air 13" mid 2011 model is having problems after I spilled some water on it. It boots fine, can access the intered and all that jazz, but some keyboard keys don't work, or do other things. Also, the air isn't charging, but when I plug the charger in it comes up not charging, and the light on the charger doesn't illuminate. Lastly, after about 20 seconds of use, left clicking becomes right clicking and it's impossible to left click, even with a mouse. This can be fixed by closing the screen and reopening it, but the effect doesn't last.
Thanks!
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
You will need to replace the upper case and probably the MagSafe board. Here the case part: MacBook Air 13" (Mid 2011) Upper Case with Keyboard
Here's the board: MacBook Air 13" (Mid 2011) I/O Board
Score 1
Comments:
Why would you replace the entire top case and not just do a KB swap?
by
Sadly, the keyboard is riveted to the upper case.
by
Add a comment
Add your answer
Andrew will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 821
