Why does the vibrator motor stop when I attach the wifi antenna?
I recently replaced a front cracked screen on my iPhone 4, and everything worked fine except the vibrator motor. Through trial and error, I found out that when removing the wifi antenna, the motor would start spinning.
With ibrate running, the motor would stop as soon as I tried to put on the wifi antenna, then start when I removed the antenna. It seems to stop running when the bottom front right clip touches the metal retainer where it clips into.
At ideas? Thanks in advance for your help!
