Model A1237 or A1304 / 1.6, 1.8, 1.86, or 2.13 GHz Core 2 Duo processor
312 Questions View all
Question Closed
Did I fubar my motherboard by hacking my MagSafe?
My MagSafe power supply went out and I tried to save a buck by cutting off the magnetic end that plugs into the computer. Then I took a universal power supply stripped the wires and tied them to the stripped end. I may have also reversed the polarity by mistake. I heard a little tiny pop and pulled it off quickly. I then went later and purchased a new 45 watt MagSafe power supply but it wont power on. Are there any parts that I can replace or troubleshooting that I can do or did I just fubar the motherboard? The universal power supply has a variable voltage that is supposed to automatically adjust. I did pull off the cover and test after the dc in board to where it plugs into the logic board with the new MagSafe supply and it had good voltage at that point.
1 Comment
If you have voltage at the output of the DC-In board, your logic board is toast IMO.
by
Add a comment
Most Helpful Answer
Before buying a new logic board, buy and install a new DC-In board and see if that fixes your problem. I don't have a schematic of the DC-In board, but it may have reverse polarity and/or overvoltage protection (doubtful). I guess you learned your lesson for the day about polarity ;).
Here's the guide:
MacBook Air Models A1237 and A1304 DC-In Board Replacement
Your auto-ranging power supply may have some lag time, so it might have applied too much voltage for a millisecond or two -- more than enough time to fry power control circuitry.
Score 4
Add a comment
Disregarding the little pop. Try to put power supply once more and wait for at least 5 minutes. Charger may not power on your motherboard, because your battery might be at critical level, after that you might have a working laptop or came to the logical conclusions.
Score 1
Add a comment
hi i turned on adapter but no light green or orange
please tell me how i can fix mainboard power on what's
problem parts in my board i trying adapter in another on
apple mac book air it's ok
1 Comment:
Please start your own question
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 4,200
