Mac running slow and fan running at high speed after water spill.
I have pretty much the same problem as "tristan" did a year ago:
''I recently spilled water on my computer and did not remove the bottom casing, much less the battery, as I now know I should have.
Precisely somes drops of water touched the back of the laptop.
I am able to start the computer and get to my desktop however at start up the fan immediately begins and the computer loads VERY slowly.
Once completely booted, the same continues. I have turned off all "at start up" settings for all apps.''
But the Hardware Test shows an error code slightly different from the one he had:
4SNS/1/0000008:Th1H--124
And these are the stats for my computer:
iStatPro
CPU
User : 3
System : 80
Nice : 0
Idle : 14
HD
U: 12,65 GB
F: 306,6 GB
Memory
Wired : 821
Active : 947
Inactive : 161
Free : 2,11 GB
Temp
HD Macintosh 25
CPU 34
Enclosure Base 25
Enclosure Base 2 25
Enclosure Base 3 24
Mem Bank A1 28
Mem module A1 34
Fan
Exhaust : 6196rpm
Battery
Health : 93%
Cycles : 497
Charge 54
Smart Utility
Hitachi HTS545032B9A302
Micro-program PB3AC60Y
Status: ok
Reseting SMC and PRAM as advised by ABCellars did not work for me.
Any help would be fantastic...
Thank you very much in advance,
Janolo
edit: I just ran Fan Control and saw that the right fan is at -1rpm while the left is at more than 6000 and at 34.2C, is it just not functioning at all?
2 Comments
Don't mess with any thing on the computer and call a technician or tech support and see if they can help you.
by oldturkey96
I finally went to a shop called "iClinique" in Brussels where I paid 115 euros to get rid of a tiny quantity of oxidated water on the motherboard. Now it's working perfectly. Hopefully it won't happen again, but if it does I will surely do it myself...
by Janolo
