Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3215 Questions View all
Home button doesn`t work, how to solve?
My home button was working sometimes but for a while it is not working at all. I am using the virtual home button under the menu of accessibility.
Is there anyway to solve this problem ?
Thanks.
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Before changing the home button try to use contact spray if this does not solve your problem i think you should change the home button.
Add a comment
Could be Home Button Flex. Could be Charging Port with Flex. Could be Logic Board and no fix. Like Loukas advised, start with Home Button Flex.
Add a comment
thanks...
Add a comment
Add your answer
Burak will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 447
