Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
Why is my iPhone 4 not turning on unless it's plugged in?
I recently replaced my cracked screen. I haven't had any problems with my phone at all. It charged, and I could call and send/receive text messages. Then, I went to a party without bringing my charger, and it was dying. When I looked at my phone it was dead. I plugged it in, and nothing happened. The Apple logo would just show up. After a while, it would turn on— but the date would say that it's December 31, and it was constantly searching for 100% battery life. I unplugged it and it turned off. So, I tried again and did a hard reset—but it still did the same thing. I plugged it into my computer, but it would turn on to just the logo and then turn off and keep looping every few seconds. I keep reading on the internet that people are having this same exact problem, but no one has answered them.
Also, while my phone is plugged into the wall charger and my phone is on, it will only last maybe two minutes. Then, this grey film appears and the phone turns off—and then because it's still on the charger, it turns back on.
Score 32
14 Comments
Hi sumera,
what was the final conculsion for your phone, I am suffering exactly the same problem new screen , everything fine then all of a sudden a week later it only comes on while charger plugged in, forever searching too. please get bk to me
by
Mel, you need to take the back off of your phone and push down with good pressure on the battery connector,trust me I work at a busy shop and see this all the time with DIY,you might also remove the retaining screw for the connector before pushing on it and reinstall the screw making sure its good and tight, good luck.
by
my phone was in perfect condition and got like 3 drops of water on the screen and its starting to do that to me today
by
Hey there, having this same problem ... I Assumed it was the battery because the phone would not hold any charge whatsoever, so I got a new battery and put it in ... tried opening it 2 times and pressing down on the connector thinking it might not be together properly, still will only turn on when plugged in ad reads '100%' could it be something else that is not allowing power to reach the battery?
- Cole
by
Same problem! have put in a new battery, it's made no difference and tried pressing down on the connector too, please someone help!
by
Show 9 more comments
Add a comment
Chosen Solution
Sumera Ahmed, the first thing I would suggest is to replace the battery. Also, check the dock connector to make sure that there are no broken or bent pins.
Score 5
3 Comments:
What's a dock connected
by
how do you do that
by
Mine is doing the same thing. but i dont know how to replace the battery
by
Add a comment
Two main issues may have happened to your [URL=http://www.forevermac.com/category/apple... |iPhone]:
1) A Dead battery, which means that it simply won't even hold the date/ time. There's always a small amount of charge left in the battery that ensures it maintains the date/ time. I suspect this is fed by battery and not the actual charger- hence it won't power on properly from the mains. Replace the battery.
2) The Power Management unit is corrupted/ your OS is corrupted. Far more unlikely.
I would replace the battery to see if that fixes it.
Score 5
1 Comment:
Thank you!!!!
by
Add a comment
i had this problem, I went out into town on the weekend, I ende dup quatting for a wee and it had dropped from my lap which was only 309cm off the floor.
It wouldn't turn on, yet I knew I had around 50% so I called it a night and got picked up. Thinking I was a little bit too drunk I thought id put it on charge in case it was actually dead..
It turned on once I put it on charge! I could not tell you how happy I was with it! but then I realised my phone was saying 100% then I knew there was something wrong, I took it off charge and it turned off this did my head in!
I pressed really hard on my battery so it could fit back in place and surprisingly this had worked my phone was freely working off charge! I was very happy! until today. it fell off my lap and down the side of my seat in my car, (which isn't far down) and now It wont work unless charging, iv tried pressing down on my battery and it works for about 5 minutes and then switches off again! :l APPLE NEED TO SORT THIS OUT! but yeah if anyone else having the same problem just try and put pressure on the battery and push it down as hard as you can so it fits back in place. Hope this helps:)
Score 3
5 Comments:
Wow thank you soo much!! It really helped(:
by
I was having the same problem my phone wouldn't work unless it was plugged in so I pressed on the back like some of you suggested and it now works! Thank you!
by
im not exactly sure were to put pressure
by
by
where do you pt pressure?
by
Add a comment
Alexa buy a $5 battery problem solved
Score 2
Add a comment
By squeezing the lower left corner you are excerting pressure on the battery connector which probably has a dry joint. Take the back off and put some card over it, when you slide the back cover back on it , it will put pressure on the connector and hold the joint closed.
Steve...
Score 2
2 Comments:
Also don't press too hard on the battery connector or you WILL crack your screen all the way across up and down... I did that...
by
You don't have many options left. This is what I would do:
Replace charge connector and if still not fixed replace the phone. This model is obselete and not worth spending money on.
Steve...
by
Add a comment
I have the same problem too, but I think another factor that causes it is the memory. Mine's almost full which I think causes also the lagging that prevents the display to turn on. Try deleting some apps to free up your memory storage.
Score 1
1 Comment:
That could be one think to do
by
Add a comment
When you remove the battery, there is a good chance of breaking or cracking the six solder joints under the piece the battery plugs onto...depending if some or all get broke, you will have different power issues...be %#*@ careful when unplugging the battery!!!! Wish that was in the instruction I read..trying to put one back on now
Add a comment
You might also want to take a look at this before you try messing with your hardware.
https://www.payetteforward.com/why-does-...
Add a comment
I recently replaced the screen on my iphone 4 verizon phone, it would only turn on if charged though a wall port, kept searching for service and read 100% battery. when unplugged it would immediately turn off and could not be charged by my mac, also the screen would freeze every minute or so and automatically restart... I took the back off of the phone, took out the screw for the battery connector and pushed REALLY hard on the connector piece, like white thumbed myself and now..... Presto! service restored and it holds a charge. Thank you for this answer!
2 Comments:
were do i press down on the back of the phone
by
my iphone 4 won't turn on even it is fully charge unless it is plug in into the wall.
by
Add a comment
i squeezed the bottom backside of my iphone 4 the it turned on but my screen still flashes once in a while.
Add a comment
My daughter dropped it in the toilet, so I took it apart to let it dry out. When I put it back together, it would only work plugged in. I knew the battery was good before she dropped it, so I knew that wasn't the problem.
I tried the idea I read here about pushing on the connector, and I felt it move into place better. Problem solved. Thanks, guys!
Add a comment
I dropped my phone in the toilet and I'm having the exact same problem and nothing has helped. My iphone has been through a lot and survived so i didn't think this would be a problem.......... It is!!! Unfortunately my power button broke earlier this week, my home button did this before and fixed it's self so i wasn't worried. But now I'm giving up it is seriously broken.............. Anyway try holding the power button and home button at the same time this has help me with other problems before. Give that a try if nothing works it's most likely broken.
1 Comment:
When I want to send a text or try to check my credits or even make a call, my iPhone 4 would just switch off and I'm looking at the apple icon only.. I will only be able to send text, check my balance or make a call when the phone in connected to its charger. What might be the problem, please help!
by
Add a comment
I had the same things . So now ur batt is connecting to ur anthena of network . When ur batt is broken ur anthena also broken . So this is PSU prob ( POWER SUPPLY UNITS ) now ur PSU is bend . When u charge ur phone PSU will give 1 power to turn on the phone . I dropped my phone on the floor it will die . So u need to repair ur PSU prob and also change ur batt for the good result!
Add a comment
Add your answer
Sumera Ahmed will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 11
All Time: 103,780
