Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
827 Questions View all
Broken headphone jack, tried to replace, but...
Ive got a new hold switch/headphone jack for my iPod. However when I went to install it I realised I have lost/broken off the little brown clip that holds the connector in place on the logic board (http://s1.guide-images.ifixit.com/igi/6G...). There is no way it will hold without the clip. Is there anything I can do, or am I able to purchase another clip?
Thanks
Add a comment
MANTA DRIVER KIT
112 bit driver kit $59.99
MANTA DRIVER KIT
Chosen Solution
Unfortunately, I'm aware of anywhere that sells just the clip.
Some have had nominal success with electrical tape holding down the cable, but this is temporary and not very likely to work.
Your best bet is most likely to purchase a dead logic board off of eBay and carefully scavenge the clip.
Good luck!
Add a comment
that happen to me with an iphone and I just had to use an electric style putty/rubber cement to fix it. I tried the electric putty on one item and haven't had a problem. However I quickly relies that with the putty it would make it difficult to re-repair if needed so i went with the rubber cement and it works great on my iPod for this purpose.
Hope this helps Ciao,
Maverick6017
Add a comment
Add your answer
George Wiley will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,926
