Model No. A1367 / 8, 16, 32, or 64 GB capacity
914 Questions View all
Question Closed
Replaced screen, it worked when I tested it, white screen after.
i just replaced the screen lcd and digitizer on my ipod 4 gen 32gb. i opened it up replaced the screen got everything hooked up and plugged it in to test it, the screen worked perfect so i then put the adhesive around the screen plugged the screen in again to make sure that i hadn't wiggled anything loose and again it worked perfectly. but then once i placed the screen and got it in place and closed up the screen now just turns white whenever anything is touched.....any insight would be greatly appreciated....
1 Comment:
try hard reset by holding the power button and homebutton at the same time
by
Add a comment
just had same issue.
I am going to try the hard reset. I hope that fixes it.
Will update in a bit.
1 Comment:
I hard resetted the ipod and it worked out after that.
I think i might have thrown out some screens because they had the white screen. :(
Thanks socoldanny82
One more thing: Usually when I install some lcds on the corners it will have some time of bleeding when I touch the non-lcd corners. It will go back to normal after only a good 2 seconds. I still do not like to leave them for customers like this. I used a new 1mm adhesive and I think it had to with that.
by
Add a comment
if reset does not fix it, just replace the screen again - sometimes the flex ribbon on the LCD gets worn very easily on these
Add a comment
Rlarajr I have the same problem after replacing an iPod 4 screen assembly. The bottom of the screen is fine but when you push on the top of the digitiser the LCD bleeds : ( anyone have a fix for this problem?? Thanks
Add a comment
I have exactly the same problem. Anyone with a solution? the screen is working fine. But only when reassembling it gives the bleed problem. I try'd with and without adhesive..
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 499
