How can I replace video ram.
how can i replace video ram? Lines on display sometimes.
Failed techTools diagnostics
First have you run Apple Hardware Test AHT. As well as try an external monitor to be sure you don't have a display issue.
If AHT passes and the problem is not present on the external monitor then your LCD display is bad. Otherwise you'll need to replace the logic board as the GPU and it's memory is soldered to it.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 491
