How can I replace video ram.
how can i replace video ram? Lines on display sometimes.
Failed techTools diagnostics
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
1 Answer
Chosen Solution
First have you run Apple Hardware Test AHT. As well as try an external monitor to be sure you don't have a display issue.
If AHT passes and the problem is not present on the external monitor then your LCD display is bad. Otherwise you'll need to replace the logic board as the GPU and it's memory is soldered to it.
Score 1
Add a comment
Add your answer
jmg will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 482
