Model A1013, A1052, A1085, or A1107 / 1440x900 screen resolution
153 Questions View all
Why does not work only a few keys?
Hi I met a strange problem. Morning and everything worked after turning off the CapsLock key at some point the keyboard of my PowerBook G4 17''/ 1.33/10.5 crazy. Some keys stopped working and more specifically the left side /Caps Lock / § /`/ the right side /= / [/ F12 / arrow up and right /I read unless all parties to the support from Apple but have not found a similar problem.
Comments:
Did you clean the keyboard with liquid or spilled liquid on the keyboard before the malfunction ?
by
Add a comment
Chosen Solution
Follow this guide: PowerBook G4 Aluminum 17" 1-1.67 GHz Keyboard (1.67 GHz LR) Replacement
to remove the keyboard. The reseat the cable connecting the keyboard to the logic board. Use a small piece of electrical tape to secure it in place.
Score 2
Comments:
Sometimes repairs can be just that simple. Glad you got it working.
by
Add a comment
No, 6 months ago had cleared the entire computer. Then he worked without problems.
Add a comment
great thanks for tip. it was the fastest computer repair. strong pressed the case between spacebar and trackpad and everything works.
Add a comment
Add your answer
Grzegorz J will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 12
All Time: 2,399
