Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3239 Questions View all
No service/searching - poor signal on iPhone.
I got my iPhone 4 about two years ago, and got the screen and backglass changed from black to white about six months ago.
I dropped my phone while it was white but the signal started to disappear, but worked again when i restored it in iTunes.
I changed the glass back because i was going on exchange in the United States for a year, but after a while the service didnt work at all. I have tried everything, almost and i still dont know what is wrong with it!
Is it my antenna that is broke or what could it be?
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
1 Answer
Chosen Solution
The options are, you need a new antenna, or make sure everything is grounded properly, check for a "blue coil" near where your antenna is and make sure its there if you don't see one you won't get service or it might be loose giving bad service. Another option is to hard reset it again. Also make sure the connector has a secure connection to the board, it might also be loose.
Score 2
Comments:
Thanks!
by
Add a comment
Add your answer
Caroline will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,553
