Will the PowerBook G5 keyboard swap out with my MBP?
My MBP has two keys that are not working after some liquid damage, I have a PowerBook that looks identical. Will they swap straight across?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
You will have to replace the keyboard. The printed electrical circuit on the layers inside the keyboard is probably cut near the A key and this can't be repaired. Replacing the key will not solve the problem.
Score 2
Add a comment
There is no PowerBook G5, you might have a PowerBook G4 Aluminum, which has a resembelence to the MBP, but the keyboard's are not interchangeable, at least without modification, which would have to be done to the top assemblies of both computers.
Comments:
You are correct, its a G4. Basically my A key does not work, thats it. I took the A key off along with all of the assembly under it and cleaned the area with alcohol and a q-tip. No joy! Any other ideas? I do have that G4....
by
Add a comment
Add your answer
Dennis will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 822
