The Kenmore Elite HE3 is a washing machine by Kenmore.
551 Questions View all
How do I turn washer back on when stopped during rinse cycle?
My washer got stopped during rinse cycle and now 'time remaining' is flashing and the washer won't turn back on or off. What do I do?
Add a comment
1 Answer
Chosen Solution
First check the control locked led and see if it is on. Try using the Drain/Spin button to turn the control locked light on or off. If nothing is responding and the washer is not in control lock then most likely you have a stuck or shorted interface. You are normally able to reset this fault by pressing the pause/cancel button twice. You can then attempt to drain and spin the clothes by starting a drain/spin cycle. I would first pull the plug from the machine and let it sit for 15minuts or better and then plug it back in. this should clear it as well. Hope this helps, good luck.
Score 1
Add a comment
Add your answer
Jackie will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 1,245
