Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
470 Questions View all
My left Palm Sensor is broken can I disable it?
The left palm sensor on my macbook pro has broken now im not to fussed that its gone but what i am fussed about is the three cores its using because my mac thinks its over heating is there any way for me to disable this sensor or fix it i have a good knowledge of computer repairs but this sensor is hiding from me! could somebody please help me get around this!
More Info
Macbook Pro 17" Core i7 4GB DDR3 1066mHz Mountain Lion
Edit: My fans still spin at full speed but if you follow the steps in this post you can get Kernel_Task to disappear and have 100% of your speed back just like ti was supposed to be!
http://www.rdoxenham.com/?p=259
Add a comment
Chosen Solution
Try resetting the SMC and PRAM on this thing. It might help you
To to the PRAM, shut the computer down press the Command, Cption P and R keys all at the same time then turn the computer on. From this point it eill restart and bong again. I would do this 2-3 times to make sure it sticks. Once it's done let the keys go.
To reset the SMC, follow this from Apple. If this doesn't work it's a sensor issue. You'll need to do surgery on the laptop. I'd go to a Apple store and get ASD run on it to see what it needs to fix the problem. Apple doesn't exactly give ASD out but people do find it. I don't want to link to a source I know has it because Apple will probably send a team of lawyers after me :-(
If it's a fan sensor just use SMCFanControl until you can get the part replaced.
Comments:
I have tried all your listed methods no software programme will throttle down my fans! is there a kext i can edit to force them down?
by
I will see if there is other fan control apps
by
Add a comment
Just replace touchpad :)
The sensor is on the backside of it.
Look here Where is the left palm rest temp sensor?
Good luck!
Add a comment
Add your answer
Dylan Roberts will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 685
