starter on 96 camry where ia it
just replaced water pump and all belts. now car will not crank. tried jumping it no good. battery has plenty spark on jumper cables.
jeanette beasley, could be a bad solenoid as well as bad fuse. If you are looking for starter etc, check on here for a great tutorial. if you have trouble finding it with those pictures, it should be on the driver side of the engine bay over the the transmission. Easiest way to find it is follow the big red cable from your battery, it should lead to the starter. Hope this helps, good luck.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,549
2 Comments
all lights bells and whistles are working
by jeanette beasley
Do your head lights go dim when you try to crank it over?
by oldturkey03
