Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3238 Questions View all
A hardware failure could cause applications to crash?
A hardware failure could cause applications to crash ??stack in respring during a safari work
its iPhone 4..all the time crashing ...any idea will be gladly accepted..
thanks
Comments:
Is it jailbroken? what have you tried so far? Have you tried ireb or any of the other recovery softwares?
by
it is not jailbroken.
it is not a recovery thing.
clean.
i did a clean Restore without a Restor from backup?
Version 6.0.1 ...
Is there anything hardware-based Wide that could cause such phenomena??
What element or antenna or chip can di this ?.
I'm really desperate I have never met such a bug.
by
Usually caused by applications and jailbreaking try this hold home button and start button for 10 seconds then only hold home button until device has the apple logo the let go and wait till your device starts up again. Also, check this video.
by
it is not jailbroken. it is not a recovery thing. clean. i did a clean Restore without a Restor from backup? Version 6.0.1 ... Is there anything hardware-based Wide that could cause such phenomena?? What element or antenna or chip can di this ?. I'm really desperate I have never met such a bug.
by
Add a comment
Chosen Solution
Try deleting your latest downloaded apps, they may not have installed fully, and do a general cleanup. You may find that with apps that need more memory to run if your phone is close to full it may cause the app to stop running/crash the phone. So..look at getting rid of apps you just don't use or video's etc eating up your GB
Score 1
Comments:
the iphone is empty
no apps
clean
by
Add a comment
Most Helpful Answer
could be a battery problem, have you tried an other one?
Score 1
Comments:
I'll keep u post .
How can it do that phenomena ?
It's in good health . Not draining fast or not getting to 100% it looks good!
by
I will
by
Add a comment
its not the battary :-(
any idears ?
Add a comment
Add your answer
tamir will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 529
