Fifth generation of iPhone. Repair of this device is straightforward, and requires screwdrivers, prying tools, and patience. GSM/CDMA / 16, 32, or 64 GB / Black or White.
2945 Questions View all
I need help removing a stripped screw by the headphone jack assembly?
I'm pretty sure on the way to removing my silent button, I stripped the screw trying to remove the headphone jack cable assembly. My overall goal is to change the midframe of my iphone 4s to red, the screw Im pretty sure I stripped is on step 32 of installing the iphone head jack cable, and its located near the silent switch. Also any direction towards replacement screws incase I may need one would be great, thanks!
Add a comment
Chosen Solution
I didn't do it this way what ended up happening was my father used some diamond edged tool to basically turn the screw into a flathead and we got it out that way...
Add a comment
Most Helpful Answer
You can Ty to drill the head off the screw then after removing the headphone jack you will have better access o the stripped screw.
Score 1
Comments:
So I have no power tool or hardware experience at all so what are the tools I would need? Do they make drills delicate enough for the iphone?
by
Add a comment
Add your answer
Jorge Sosa will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 29
All Time: 962
