A1278 Logic Board Issue
Hi there,
First post asking for help on here.
I recently got hold of a Macbook Pro which has spill damage. I've stripped it down, replaced the keyboard and removed all the corrosion with alcohol, although there wasn't much. I took the logic board out of my current working model and the system works fine so I know this problem is solely relating to the logic board. Basically, when I connect the battery up it will automatically power up, I'll hear the welcome chime and the screen comes on then it just cuts out. The same will happen if I connect the magsafe adaptor, but if both are connected nothing happens. The charging light on the magsafe functions as it should when both are connected. I've given the logic board a wash down with alcohol but there has been no change.
Anyone have any ideas what might cause the problem and if it's salvageable?
Thanks
