Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
416 Questions View all
Replace fan or lubricate the bearing?
My Late 2008 MBP is starting to show age and the right fan is making more noise as of late. I replaced it sometime last year and was wondering if I need to do it again or if adding WD-40 to the inside of the fan would be a better and cheaper option?
Add a comment
1 Answer
Chosen Solution
I wouldn't put any lube (or anywhere inside) on the bearing as it would likely spray all over the place causing other problems as well as act as a dust magnet.
I would take a soft brush and can'ed air and clean the blades and the heat sink grill of all of the dust buildup. I would also get the dust buildup on the logic board as well.
Once things were clean I would see if the fan was still having problems. I would try putting some isopropyl alcohol on the bearing (just a small drop) to clean it. If that still didn't help it's time for a new fan.
Score 2
Add a comment
Add your answer
cntrabnd2000 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 1,103
