How come I am getting bad Cellular signal after replacing my screen?
Okay so i bought a new screen for my iPhone 4S and I replaced it successfully. My only problem now is the Carrier Network (AT&T) is not working well at all. Like i get a call failed a lot of times and the internet doesn't always load a webpage and says cannot activate cellular network. Sometimes a person cannot hear me if i get a call through but i can use an app over wifi and they hear me just fine so its not the microphone. I did have an issue when replacing the screen. The top screw on the battery connector shield got forged (stripped I could not take it off using a screwdriver). I had to use a drill bit and drill the head off because it would not come out. Now I don't have a shield over the cellular antenna because the bottom half of the screw is still on the motherboard. Could this be causing this issue or is it possible the antenna wire shorted out during this process? Everything else on the iPhone 4S works great so I do not believe its a motherboard problem. Thanks for any help given in advance!
Hi,
I have exactly the same problem.
I replaced the front and back panel on my 4S and i do not get any signal at all since i finished.
I did not find any solutions and everthing seem to be fixed like it should be.
I'm kind of lost....
I think i start again step by step....
Did you find a picture how the whole antenna thing should look like once properly installed?
by Pinky
