How do I replace fan (s) on Eee PC? MOD#-1005HA-VU1X-BK (from bottom)
Fan (or fans) makes noise. How to replace w/ maybe heavy duty one? Also best website with pics?
Thanks,
HG...
Thanks,
HG...
Mann, here are some instructions:"1. Inorder to replace fix or install your new Asus 1005HA laptop fan and heatsink, you will need to open up your laptop. You can do this by removing the screws from the bottom of the laptop.
2. Once the screws have been removed from the bottom of your laptop, you can now remove the keyboard and plastic bezels from your Asus 1005HA laptop.
3. You will see your Asus 1005HA Fan and Heat Skin exposed.
4. Use a screw drivers and remove the screws from you Asus 1005HA HeatSin Fan.
5. Before reinstalling the new Asus 1005HA Fan onto your laptop, you can clean the Asus 1005HA Fan. To clean your Fan and Heatsink, use a can of air and blow out any dirk from your Asus 1005HA Fan. You can also use a paint brush to clean out the dirt from the hard to get areas. Somtimes cleaning your Asus 1005HA laptop fan will actually repair it. Dirt can cause the Asus 1005HA Laptop Fan to make noise and even stop spinning properly. Source.
Also, check this video as well as this one. Hope this helps, good luck.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,482
