2.2, 2.4, 2.5, or 2.6 GHz Core 2 Duo processor
933 Questions View all
Won't Power on or anything else.
This computer wouldn't power on at all, no fan, no sleep light, nothing. I replaced the left I/O board, and still nothing. I tried to reseat the RAM, with no effect. I am using a known good power adapter, and whenever I plug it in, it lights up green as if the battery is fully charged. If anyone could help me I would appreciate it.
Add a comment
Chosen Solution
Did you try the SMC reset ? If not check this link:
Score 2
I did this, but still no response.
What is the MBP history ? Liquid spill, dropped ?
Nothing. The first symptom was a pink screen with a question mark, and then nothing ever again.
remove the top case and double check your top case ribbon cable connector to the logic board socket. If the ribbon cable is no well secured to the connector the computer wont boot.
- pink screen is often related to a failing backlight lamp
- question mark indicate that the computer can't find a valid OS to boot from = corrupted / damaged OS or bad hard drive.
Add a comment
Hi I have the same problem occurring right now, did you fix your mbp?
Add a comment
Add your answer
josephcherven will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 995
