Non-Unibody, Core Duo & Core 2 Duo Processors
452 Questions View all
8GB of ram in a A1212?
Is there a logic board I can put into my A1212 and be able to put in 8GB of ram? All the rest of it works great still, but I'd kill for some more ram... is my only option to upgrade to a new notebook?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Unfortunately, no. There's no way to upgrade your machine to accept 8 GB of RAM. Sorry!
Score 1
Comments:
+ Ralph
by
Add a comment
Most Helpful Answer
It all depends on witch Core 2 Duo MBP you have. Look up your exact model on the list (you will find it on the bottom of the computer or under the battery) and you will see the maximum amount of ram your computer will use. As you will see the newer MBP's will take 8GB. Ralph
http://www.everymac.com/systems/by_capab...
Just checked Mactracker--if your computer is a Model A1212 them your max memory is 3GB. That would require two 2GB sticks but only 3 GB would be seen. Ralph
Score 2
Comments:
I'll leave it to Ben Eisenman to say as to whether you can swap logic boards or not. Ralph
by
Add a comment
He could use one 2 GB stick and one 1 GB stick, which would be way less expensive than 2 2 GBs.
Add a comment
Add your answer
Noah Nordrum will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 4,079
