Fifth generation of iPhone. Repair of this device is straightforward, and requires screwdrivers, prying tools, and patience. GSM/CDMA / 16, 32, or 64 GB / Black or White.
2940 Questions View all
Replaced/Repaired cracked screen. Touchscreen not working...
I have disassembled and reassembled the new iPhone 4S display assembly. First off, the entire repair was so tedious with having to take apart the entire phone. I checked the new assembly thoroughly for cracks and bends or breaks in the cables and everything seems fine. I even rebooted the phone several times as well. Home button works fine. Volume buttons function, power button works. I just can't get any response from the touchscreen....
Anyone experiencing this issue/problem?
Worked so hard on this thing... So upset...
Comments:
Hi, just did the display replacement on the 4S and everything went perfect including the startup BUT touchscreen potion doesn't work. I can't unlock phone because no where on screen does it sense my touch.
Did you ever find the issue with yours ?
Frankie5angels@mac.com
by
double check that the connector for the digitizer is seated properly and that you didn't tear the cable. a digitizer DOA is rare.
by
Add a comment
Chosen Solution
I would not be surprised if the digitizer is bad if you double checked all the connections. See if you can RMA it through who you purchased it.
Add a comment
You most likely sliced your ribbon cable while you were putting it threw that little slot in the metal frame its very easy to do.
Add a comment
Add your answer
1force1 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,466
