Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
779 Questions View all
Can anyone help identify smd components on my logic board?
Hi all
I have cleaned the the logic board of my early 2011 macbook pro 13". When cleaning 2 small components and a larger component were found to be damaged and hence removed.
I do not know the value they measure and was wondering if anyone with the same board would be kind enough to measure the components and let me know of the values. I have circled the components on the images below.
I would be so grateful if someone could help as I cannot find informational such as schematics and have been trying to fix my macbook for aaaagges. PLEASE HELP?
Many thanks in advance to anyone that will help..
Cheers
Add a comment
Chosen Solution
This is a really old question but I thought it would be okay to answer. Just in case somebody is having issues with their 820-2936 board and finds the same components to be faulty.
Reference designator R5095 is a 10K 5% 1/16W resistor in a 0402 package
Reference designator C4902 is a 22UF 20% 6.3V cerm capacitor in a 0805 package
Reference designator C4903 is a 0.1UF 20% 10V cerm capacitor in a 0402 package
Score 1
Add a comment
Most Helpful Answer
Hi, the only way a person is going to be able to help you is if they have a capacitance meter with them to measure the capacitance.
How to identify SMD capacitors :
- Ceramic capacitors : generally small, grayish or brownish body with metallized edges, generally unmarked -> capacitance meter !
Values under 1nF generally are C0G dielectric (high quality), higher values are X7R, Z5U, etc, good enough for supply bypass... Color is generally greyish for C0G and brownish for other dielectrics, but the size is a guide : a small cap with a large value cannot have a good dielectric...
- Tantalum : most are molded , black or sand body, marked value/voltage, band identifying positive polarity, electrodes are formed metal. Some are unmolded with an orange body, metallized electrodes, positive having a protruding bar, value not marked.
- Electrolytic : Most are miniature standard types with a plastic base and formed wires, value marked, band identifying negative polarity.
http://www.diyaudio.com/forums/solid-sta...
Hope this was useful. Good luck.
Score 1
Add a comment
maybe you can have try this website http://www.smdmarkingcodes.com for check marking code/smd code
Add a comment
Add your answer
Anthony will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 1,782
