The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
781 Questions View all
possible to kill the ps3 w/ heat gun? ylod fix failed
I attempted and failed the ylod fix. I applied the heat gun over the chips for an overall length of 4 or so minutes at a proximity of about 2 or 3 inches from the board. When I put it back together, it wouldn't turn on and only display a faint red light.
I attempted the fix yet again and the second time allowed the system to turn on, but only briefly - about 2 seconds, during which time the light turns green, the fan starts spinning and then shuts off. The yellow light is not present in this process at all, as it used to be before.
Does this mean I broke my ps3? Im concerned I may have over blasted it w/ the heat gun.
1 Comment
You might want to try the oven fix. Google it.
by
Add a comment
1 Answer
Most Helpful Answer
There is no way that someone with just a heat gun can properly reflow a PS3. You have to get the solder under the board to a liquid state which is approximately 225c, that takes a *@#^ of a lot of focused heat to get it through the heatspreader and through the chip. If you were able to with a heat gun then it would require thermal couplers in place to determine the exact temperature. With a heat gun you would also be required to cover the numerous capacitors on the board so they don't fail since they hate to be at a high heat for too long.
It is very likely that the PS3 is now pooched. Oven fix may reseat the processor but it won't be a proper reflow.
Take it to a qualified shop and get them to fix it if they still can.
Kevin
Score 2
2 Comments:
that's what i thought. I'm going to have to check if my school will let me use their equipment to reflow those annoying ball pin array chips... but before that - into the the oven!
by
Did you fix it by baking
by
Add a comment
Add your answer
mahjixien will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 2,330
