Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
820 Questions View all
My SD Card slot won't read.
for some reasons, my MBP's SD Card slot won't read... so I have to put the SD card inside a USB card reader, then it reads...
Is there anyone who got this experience as well?
Thank you...
Update
Thank you,
I did take a torch (flashlight) and trying to find if there's any bent, but I couldn't see anything. By the way, when put alcohol, must I use a cotton bud? One more question. I just remember that I had disabling the auto download feature on the iPhoto, as I put the SD card in the slot, the system will automatically downloading pictures to iPhoto. Then I didn't remember how, but I ticked any option to disable it. Could this be also the reason why my SD card slot won't work?
thank you ;)
Score 1
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Hi, take a torch and look at the slot to see if there are any pins bent or missing. Also check for any corrosion. Clean with isopropyl alcohol. be very careful when cleaning as you dont want to damage it. Write back on what you did. Good luck.
Score 1
Comments:
Hi, yes use a q-tip (cotton bud) to gently clean it. If that does not work, then I suppose there is something else wrong with it. I would suggest not to repair it as card readers are cheap to get.
by
Add a comment
Add your answer
Bowie Djati will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 47
All Time: 4,034
