AirPort signal weakens with temperature - what cause?
My faithful MacBook1,1 (now running Snow Leopard) has recently started to have problems with the AirPort. This appears at home and in different locations, base stations, and I've checked with two other systems that the WiFi signal at home is stable.
When I turn the mac on (or awaken it from sleep) after it has been off/asleep for some time, I have good WiFi signal (~54% on iStumbler), see neighbouring networks etc. I can see that initial chipset temperatures are ~35C (using Temperature Monitor).
Within a few minutes, as the chipset temp raises above 48C, the signal from my router drops to <25%, the neighbours disappear. In other places, where the initial signal is weaker, it goes below 15% and I lose connection.
I have tried to disconnect and reconnect the antenna connectors and clean the Airport card connector, but with negligible improvement.
If I keep the fan fixed at 6000RPM (with smcFanControl) the chipset stays around 45 deg. and the WiFi signal remains at ~30% (or less but just usable where the signal is weaker at the beginning).
Can someone suggest what I can try to decide if it's an AirPort card problem, an antenna problem or a motherboard problem? Being this an old laptop, I don't want to waste money replacing the AP card if that is not the source of the problem.
PS: the card is the standard AirPort Extreme (0x168C, 0x86), FW Atheros 5424: 2.0.19.8; running Mac OS X 10.6.2 (10C540)
8 Comments
Answering myself, for other people's reference.
I've run the MacBook open, sliding the keyboard to the side, and by just blowing air on the card I could get back the full signal. So I've decided to replace the card, and now my wifi connections are back to what they used to be.
Problem solved :-)
by Sergio Ballestrero
Hi, first off, good job solving it yourself, but can you please post your solution as an Answer and accept it, rather than a comment, so that this can be removed from the Unresolved and No Answers section? Thanks
by rab777hp
I can't - the interface (at least using Firefox) has an empty "Add Your Answer" section for me now that I'm logged in. Either it's a bug or iFixIt doesn't expect people to solve their own problems? ;-)
Interesting - now that I've accepted the answer from rab777hp I have the "Add Your Answer" text input...
Are you sure this is all true? You may want to make a post in meta.ifixit.com to give them a heads up about a bug
by rab777hp
Show 3 more comments
