Model No. A1367 / 8, 16, 32, or 64 GB capacity
1283 Questions View all
iPod Powered Up, Black Screen?
Alright been sent in an iPod that was self-repaired by the customer.
They said they replaced the screen and all was well and they tested the new screen before sticking it down and it worked fine.
After they laid the adhesive and plugged the screen in again it was just white (white screen of death) and the hard reset didnt work. After hard resetting a few times the iPod's screen just went black.
Now i can't see the problem. The LCD connector on the board is intact. I've tried out test screens and they have the same result.
I cant see any damaged chips/caps/ics/resistors on the board but i am no expert.
Is there somewhere i should be looking? The iPod powers up, recognized in itunes, makes sound. I even updated it to iOS6 and restored it.
Add a comment
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
Chosen Solution
I experienced the same problem. To get to lock screen press the power and volume down at the same time and it should go to the lock screen
Add a comment
If the hard reset is still not working (can take up to 20 secs) then i am guessing when the screen was finally laid to rest, too much pressure was applied and damaged it. Do you not have another screen handy to test with? You only need to connect the LCD part to test, not mess about with the digi flex.
Add a comment
Add your answer
Craig will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 25
All Time: 3,496
