Model No. A1367 / 8, 16, 32, or 64 GB capacity
1283 Questions View all
How do I fix the screen not lighting up?
when i turn it on the screen does'nt light up .Its very dimhow do i fix i
Add a comment
Chosen Solution
edwin, it is possible that your backlight has failed. the usual way of fixing that, is by replacing the front display assembly. There are chances that it could be the IC on the logic board, but start with the LCD first, it's the easiest to fix. Use this guide to work on it. Hope this helps, good luck.
Score 1
Add a comment
You say your iPod won't light up? You can force your iPod into recovery mode then try again. The given tool is a free and safe program especially designed to enter and exit iOS recovery. Don't need to restore and connect to iTunes, just one click to make it!
Add a comment
Add your answer
edwin will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 9
Past 30 Days: 34
All Time: 3,554
