Model A1013, A1052, A1085, or A1107 / 1440x900 screen resolution
153 Questions View all
How can I completely remove the screen?
I want to remove the screen from my PowerBook G4 so I can use the base as a computer attached to my TV without any loss of functionality (I understand Airport and the Bluetooth antennas are connected to the screen?) All help appreciated!
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
I would follow the directions for removal of the LCD screen first as described here: PowerBook G4 Aluminum 17" 1-1.67 GHz Display Replacement
Then you should be able to remove the hinges.
Score 2
Add a comment
You can separate your display assembly from your bottom case using the link mayer posted in his answer then open the display and remove the airport/bluethoot antenna cable. Simply reconnect the cable to your logic board and you will restore the wireless functionality.
Score 2
Add a comment
Add your answer
Dave Robertson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,169
