nothing happens when "on" switch depressed.
No charge lamp lit prior to switch on. No lamps illuminate, no noise, nothing happens when "on" switch depressed. Same occurs with battery removed and ac supply (which is correct) is plugged in. This looks pretty terminal yes? Grateful for any advice, thanks.
How did you check your AC adapter? Use a multimeter and make sure that you are supplying the proper power to your computer. Check your DC power adapter, make sure it is still properly attached. Use a multimeter to check for power in. What have you checked on so far?
by oldturkey03
