Fifth generation of iPhone. Repair of this device is straightforward, and requires screwdrivers, prying tools, and patience. GSM/CDMA / 16, 32, or 64 GB / Black or White.
2940 Questions View all
Is it possible to fix the sim card slot?
On my iphone 4s, one of my friends was trying to eject my sim card and actually jammed the sim card in the phone. I was wondering if the whole sim card Assembly can be replaced with a new one. thank you
Add a comment
1 Answer
Chosen Solution
try using a paperclip and angle it into the hole and lever the simtray out. Unfortunately you can't access the sim tray any other way on the IP4S/IP4 from the inside so easily. You may be able to take the back off and fit a small screw driver or pin just above the screwhole on the frame (far left near where the battery plastic flap lies) If you use good light you can just about make out the simtray edge..
Score 1
Add a comment
Add your answer
Gerardo will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 11
All Time: 2,458
