Usb / SD Ports damaged
Hello,
2 weeks ago I found out that my sd card was stuck in my macbook pro. I didn't kow why, but it was stuck.
After a lot of safely pulling the sd card got out, but since then my sd port and my usb ports has been damaged.
If I put my external HDD in one of the usb ports, and I move my laptop a little bit or I replace the HDD, I get the warning that I not proper eject my HDD.
So, both my usb ports and my sd port are damaged, is there a way I can fix this?
1 Comment
Can you supply the last four digits of your serial number so we can correctly ID your system. Depending on what you have you will either need a new main logic board or a I/O board.
by Dan
