Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3230 Questions View all
Replica power button not making good contact
I am trying to replace the metal power button on an iPhone 4, but upon installation the power button is not making good contact with the power flex. I have compared the original button and the replacement and there is a slight difference.
This pic shows what an original one looks like:
and a replacement looks like this:
so you can see the first has some sort of spacer.
Now I tried to remove the spacer of the original with out luck please can someone advise me how to go about installing this new button.
(I also have similar problem with the volume button)
Add a comment
1 Answer
Chosen Solution
You need to ad the spacer behind the new make a little bump....or you can drop a little crazy glue to make a bump behind the new button....
Score 1
Hi, Thanks. I finally removed the little bump, it looked like it was part of the power button. I simply used a hair dryer to heat the bump up and the with a flat head screw driver popped it of. Once again thanks.
Add a comment
Add your answer
Dean will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 474
