A comprehensive set of repair information regarding objects with specified tasks, usually for fixing or building.
320 Questions View all
What is the conversion for Ph000 to mm?
I bought the kit of drivers. The phillips ones are going by size as PH000, PH00, PH0 and so on. On your guides you only mention mm of the screws. How does one convert your indications to the right size of screwdriver?
Thanks a lot!
Add a comment
1 Answer
Chosen Solution
Capitanmerloc, the mm is the thread diameter of the screw, not in direct relation with the screw head. Phillips screws, even metric ones, use the PHXXX for the screwdriver size. There is no conversion. Here is the description about the Phillips head screws, in German, and it does explain it :-)
Score 3
Add a comment
Add your answer
Capitanmerloc will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 37
Past 30 Days: 168
All Time: 6,009
