Repair information for tools used for specific tasks like fixing, building, or cutting. Learn how to use tools that work to fix the ones that don't.
2222 Questions View all
What is the conversion for Ph000 to mm?
I bought the kit of drivers. The phillips ones are going by size as PH000, PH00, PH0 and so on. On your guides you only mention mm of the screws. How does one convert your indications to the right size of screwdriver?
Thanks a lot!
Add a comment
1 Answer
Chosen Solution
Capitanmerloc, the mm is the thread diameter of the screw, not in direct relation with the screw head. Phillips screws, even metric ones, use the PHXXX for the screwdriver size. There is no conversion. Here is the description about the Phillips head screws, in German, and it does explain it :-)
Score 4
1 Comment:
I just bought screwdriver set for repairing electronics with Philips screwdrivers labeled 1.2, 1.5 and 2.0. Seems they should have equivalent sizing among phxxx system
by
Add a comment
Add your answer
Capitanmerloc will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 14
Past 30 Days: 55
All Time: 14,175
