How do I replace a ceiling light fixture?
I have a ceiling fixture that quit working. Everything else in the room works, just not it. How do I go about replacing it? I assume I'll have to kill the power in the room. Never done electrical work before. Hope it's easy on this one.
Update
I already checked the light bulb. Tried a couple of newer ones, no effect. Tried the original bulb in another lamp--it works.
1 Comment
So it does sound like either a bad socket or bad wiring. Depending on your light fixture, check the back of the light bulb socket. The wiring may actually enter there and it may be secured with some set screws that may have come loose. Do you have a multimeter, or are you in a place where you could acquire one? Just a cheap voltmeter would do.
by oldturkey03
